carolinadarin
Thread starter- Joined
- May 28, 2008
- 7
Hello,
I am a fiberglassing newbie forst off. So I ripped up the carpet on my 1992 19' Bayliner Classic and found some rot beginning on the deck. One side of the foam was waterlogged and I ripped it out. The other side was completely dry. I cut out the rotted areas and and replaced them with plywood. Sealing the seams initially with foam so the resin wouldn't leak through.
Now I glassed over the wood, but only used the fiberglass cloth on the seams. Should I have used fiberglass mat over the entire floor to be safe? Should I now sand the entire floor and put another layer of glass and mat on it? Or will it hold up the way it is? (fyi - I am putting down Nautolex Marine vinyl flooring so water wont run right through it like carpet I dont think)
I have attached some photos for you guys to look at. And I appreciate your advice in advance!
