NS5B CD Unit
trimjb
Having problems running my 5 hp 2 stroke. Will run for short time then act like you pulled the stop switch. I unplugged the stop switch and read the brown wire on the switch and black wire on the ground with meter. Stop switch is closed with the switch in, open with the switch pulled out. Switch is good. Next moved to the brown wire to the CD Unit (plug in for stop switch) and to black ground. Reading thru the CD Unit I get about 30 OHMS (X whatever scale I was on). Should I be getting a reading to ground from the brown wire? Shouldn't this read open?
John
TOHATSU GURU
Re: NS5B CD Unit
The values and procedure for checking the CD module can be found in the service manual which is available from any Nissan or Tohatsu dealer.
