Nandy
Thread starter- Joined
- Apr 10, 2004
- 2,145
Model 70573-b, serial J0001631. I replaced the pump with the new improved pump, did a carb job and installed a new thermostat. I attached the water muff and fired the motor. I was a little apprehensive as this motor does not have the telltale stream of water. I kept feeling the motor until it got a bit more than warm to the touch than what I liked. I killed it and took the thermostat cover out. Much to my dismay the thermostat was dry and there was no sign of water anywhere.
First I thought since I have well water where I am working the motor maybe the low pressure was not helping the pump. But I could see how the amount of water escaping around the water muffs was a significant less than when the motor was off. I also noticed a lot of water coming off those vents a bit higher in the lower unit.
I am theorizing that maybe the pump case did not set up right in the water tube and that is my problem. If not then something is plugging the water tube or another section of the water jacket. If I dont see anything wrong with the pump or the connection from the water pump to the water tube then I will use an old cut water hose attached to the water tube to see if there is water flowing to the water jacket then. If I still dont have water it must be something in the water jacket/tube.
Anything else that you guys think I should check? I have changed plenty of impellers so I am sure I have the impeller blades fold correctly but I will check that too.
Thanks!
Thanks!
