Bypass quick disconnect??
btaylor507
I have a 1957 Evinrude FastWin 18 hp and it uses the old pressure fuel system. I seem to have bad o rings in the quick disconnect. Would it be ok to bypass this and run the new fuel lines directly to the motor. I don't plan on pulling my tank out to refill. Please let me know if this is a good idea? Thanks
Re: Bypass quick disconnect??
you can do that, or just replace the orings.
btaylor507
tashasdaddy thanks for the reply. I will do this for now untill I can find the proper o rings.
F_R
part number 301824 special size and available only from your dealer. Other ones on the market are the wrong size.
