buttapollock1010
- Joined
- May 30, 2008
- 4
I have a 98 130, it started the other day would not go above 4300rpm. Motor would cough and sputter/cut in and out when at this rpm but as soon as I dropped it down to 3000-3500 it would smooth out. I continued to run her thinking its bad gas and it may work it self out. It now will not run over 3000rpm and will not plane out. I have done test to the motor and the left side two cylinders are not running. I have done a compression test good 140ish on 3 and 150 on the other. I have spark on all 4, The motor is running only on the right two cyliners. I have taken the carb cover off, squeezed the bulb no difference, I have sprayed fuel into the carbs with not much of a difference. I have drained the carb bowls and primed the bulb letting fuel flow out of them. It seems to not be firing. I have just recently replaced the fuel/water sep filter and plugs. The plugs were changed right before the problems started, fuel water filter just after. Any help would be greatly appreciated. Motor was rebuilt, before I purchased the boat.
Robert
Robert
