Re: no spark from number 2 plug***FINDINGS*** HELP***
another question. I have 2 modules. there is a red wire that is not connected to anything, I'm assuming that this would be for the 4th cylinder. can i hook the bad 2 cylinder (middle) , from the 1st module to the second module some how. ?
If you have Prestolite Ignition (blue modules and coils.)
Try swapping the number 3 coil with the number 2 coil and see if number 2 now fires and 3 doesn't, if number 2 now fires and three doesn't you've got a bad coil.
If all checks out with the coils you can swap modules!
Each module is designed to run 2 cylinders, the extra wire on the no.3 module was designed to be used on the 4 clyinder motors.
You can switch the modules and wiring around and have 3 firing cylinders, providing the extra half of the module on 3 hasn't already been used and (is in good shape.)
Swap the entire module and wiring! (If not yor engine will be cross firing out of order.)
Switch the no.3 cylinder CD module and wiring to the no. 1-2 cylinder position then you will have fire on both the 1-2 cylinders.
Put the (good half) of the 1-2 cylinder CD module and wiring on cylinder 3 and you should have fire on the number 3 cylinder with the bad half of the module as left over wiring, no need to buy a new module you had your own spare all along.
Take pictures before you start so you don't get the wiring for the CD modules mixed up while swapping the modules and wiring around.
When doing this you should have a manual with wiring diagrams for your motor handy!
Good Luck!
