Re: briggs 5hp
I'm not sure I follow you, but it sounds like if your motor broke free on the trailer, you may have spilled some oil into the cylinder. Set the thing upright, remove the spark plug, and pull her over a couple of times. Check your oil level, replace the spark plug and give it another try. If there was oil in the cylinder, it may take many pulls on the starter to get it to fire. You also may need to remove the plug two or three times during this process to clean the electrode off as it will get coated with oil.
