OMG did I just create a bigger problem. **UPDATE AT BOTTOM**
macr6
Bone head mistake of the season so far.
It just thunderstormed here really bad. I had the drain plug in and the bilge just filled up with water right up to the bottom of the engine and just about half of the starter. What kind of damage did I just cause?
fishmen111
Re: OMG did I just create a bigger problem.
I think you will be OK. I have done that before with no after effect. To be on the safe side, check your oil for water after you run it a few minutes or just change it. Take off you starter and blow it out with compressed air and you should be fine.
Wotknot
Been there, done that...... :redface:
Coors
Just to the bottom, you are lucky. wd40 actually works for this-hose it down, and keep starting it for 2 hours, on the muffs.
That should get the wd40 into the whole starter,
But then, again, a wet starter will die on you.
bigbob_FTW
this happened to mine, and I didn't check it for some time. took the starter apart and sprayed with WD-40. Was back in business in no time.
Don S
If murphy (of Murphies Law fame) has anything to say about it, if you do nothing, it will die completely from rust and corrosion on the 4th of July 3 day weekend. Probably the first day, at the ramp.
Take it apart, clean and dry it now, avoid the July 4th rush for parts.
Bt Doctur
On a side note, it sounds like your auto bilge isn`t working properly.
check the float switch and have it wired direct to the battery thru a fuse.
macr6
Thanks guys will do. Is there a blow up of the starter on how to take it apart or is it pretty straight forward?
Also water was over the gas tank, there shouldn't be any way that it got in there right? Just paranoid.
Coors
The brushes are just tricky, you will figure it out.
macr6
That's the problem. My bilge pump is manual :(. Should have gotten an automatic one installed at the shop.
Found the old manual that I downloaded from a link on here. If anyone needs it I'll see if I can put it up somewhere for download. If anyone has a spot to put it let me know.
You have to pull the starter. That is for sure.
fishmen111
Should also be OK. Gas is thinner than water. If gas was not leaking out before this, water should not have leaked in. I assume you are not running a fuel/water separator. If not...you should be.
macr6
No I am and it's brand new but I guess I should replace that too seeing as it was under water. :(
I swear as God is my witness I will never ever do that again. What a time consuming lesson to learn.
rodbolt
BEFORE attempting to start it, clean the starter. sometimes brush dust and water will fry a commutator when power is applied.
second as long as the carb vent or tank top wasnt submerged I would not worry about fuel contamination.
if your runing an SX, Cobra or mercruiser drive then remove the drive and inspect for water intrusion.
if its swedish volvo do the same but insure you grease the bellhousing gimbal fitting.
not knowing what drive package your running I cant say much more.
if its inboard carefully check the transmission fluid for water intrusion.
Wotknot
If there was only 1 lesson that I've learned in life, it's NEVER SAY NEVER. :rolleyes:
bamadave
That's the problem. My bilge pump is manual . Should have gotten an automatic one installed at the shop.
Shoulda, woulda, coulda.
Get a float switch installed to the bilge pump. It will save you lots of aggravation, promise.
macr6
UPDATE***
Took the starter off the motor and took the cap off. The starter is fried. Half of it fell apart in my hands. One of the brush springs looks like it was half melted. It fell out and half of it turned to dust :( Looks like the starter need some attention. Now it's off to find a new one.
Anyone know which of the two starters in the manual I need for that motor? It's a 98 3.0L 4cyl merc. Serial is L059777
Don S
The Merc number for the starter you need is 806965A2
macr6
Don I was looking at a parts list online and they had it as 50-806965A4 for L096999 and below serial numbers. Does this one supersede the one you posted?
