fishdog4449
Thread starter- Joined
- Jul 16, 2007
- 462
First off, this is a great site and I have learned more about boats from the experts on this site than anyone else!
Ok, I am starting a new topic about this because it has me so baffled.
Engine is a 1980 merc 80
Memorial day weekend after about running EXCELLENT for 3 hours on lake anna I started noticing increasing hesitation when throttling up. after shutting the motor off so my kneeboarder could get back in the boat, it wouldn't start. tried various combinations of fast idle lever, choke, and pumping bulb. tried both gas tanks and reserve tank. engine would turn over, kick the bendix back down, and die. bulb was hard, but when pumped more, fuel was leaking from somewhere in the front of the engine.
got a tow in, about 15 minutes later, I gave it full fast idle, but no choke and it sputtered for a few seconds then revved up to normal fast idle speed. died when returned to normal idle.
Yesterday, I tried to start it on the muffs. Pumped the bulb HARD and no fuel leaks anywhere. Started within 1 second cold. Idled fine for 20 minutes before the neighbors got mad.
Here's what I know:
Compression 120PSI across all four.
Spark on all four cylinders.
Carbs rebuilt with new needles, seats, gaskets, and floats. floats set properly.
Water pump functioning well, engine running at normal temperature (checked as soon as motor started hesitating).
Gas was fresh.
Fuel pump rebuilt last fall.
Plugs are one year old, didn't look fouled.
thanks in advance for the help guys this one has me confuddled.
Here's what I know:
Gas was fresh.
