Advice on fixing holes and cracks.
tommays
Re: Advice on fixing holes and cracks.
Well
Most of what i see is cracks around cleats from the glass flexing SO without making the boat stronger in those areas OR putting much bigger backing plates to reinforce them it is hard to say how long a surface repair would last
More will come along and give better advise
Is that a sailboat :confused: as people with the same type of boat my be able to offer specific advise
Coors
Yep, bigger backing plates.
oops!
toms post is totally correct......
pic #1 and 4 are gellcoat crazing caused by immpact damage....
i think youll find those cracks go straight thru the fiberglass.
grind out the affected area clean with acetone.
you might want to add a layer of glass matt
then fill with marine tex....or fill with gellcoat
htuong95
Thanks for the input guys. The boat is a 14' glasspar Lido.
