I have a 1995 Johnson Ocean Runner, V4, 115HP
I've had her for 2 years, with no problems.
Cold start:
-Pump the bulb a few times.
-Turn the ignition and press to prime.
-Fires up as normal.
-Runs like a champ thru the entire range.
Warm re-starts in the past:
-Just a bump, and she fires right off.
New troubled warm re-start problem: (Duplicated on hose, or in water, whether right away or 15-30 minutes later, and you can smell gas, almost like a flooded state)
-Engine turns over a lot.
-Let off the key, and then turn over some more.
-After a few more times, sometimes opening the throttle in neutral, she eventually lights off, and runs fine the rest of the time.
A chink in the aromour of confidence for her. How can I get that confidence back?
Any advice is greatly appreciated.
Thanks, Harry
Cold start:
Thanks, Harry
