I will try to be as specific as possible: I acquired a power trim system but the pump motor was very weathered so to save a buck i decided to rebuild this pump...the only problem is, when i disassembled the control valve body i laid the parts out in the order they came out...springs, check balls etc.,thanks to my cat for jumping on my bench and scrambleing them before i could document the order in which they were disassembled...its a mid seventies pump, round motor, large square reservoir, has the reverse lock-out thumb knob, i believe its prestolite but not sure, where can i get an exploded view of the exact order inwhich these parts are assembled? i watched closely as i disassembled it but don't wanna go on "i think" this is how it was...thinking isn't knowing...so i need guidance! thanks iboats
