Don't leave the dock without...
Andy in NY
What are some of the important items to have on a boat that alot of people tend to overlook?
fishmen111
Re: Don't leave the dock without...
Toilet paper, sun screen, bug spray, cell phone, gallon(s) of water, extra high carb food, cold weather gear (yes, summer too), 5-gallons spare gas, tool kit, wire ties, duct tape, fuses, aluminum foil, rubber bands, single strand wire, Marine-Tek, McGuiver video:D, spare points if non-electric ignition on I/O, spare prop with floating prop wrench, new larger boat to carry all the added weight of the crap I take........;)
first aid kit, a good one.
External Combustion
The above items in waterproof containers, especially the cell phone. Guess why I recommend that.: (Most boaters around here forget an anchor and anchor line, handling lines, a paddle or oars for the smaller boats, a marine radio (with weather channels preferably) spare life jackets, a boat hook though not neccessary is absolutely addicting once you have one. A paddle can be bought that has a hook on the opposite end of the blade. Spare drain plugs and some tapered wooden dowels for emergency plugs. Flares, emergency flag, smoke cartridges to match where you use your boat. A ball of string to make lanyards for your tools while you use then over the water. A roll of electricians tape.
Fishmen111 was spot on with his list. I wish I could count the times I have been asked first for water when I have come upon a stranded boat.
I keep most of the small items in ammo cans because they are waterproof, inexpensive and can be labled. (I never have labled mine yet though, except the first aid kit. Hmmmmm) Everything except the oars, ground tackle, life jackets and handling lines will fit in three fifty cal cans.
Now, if you have a steamer....add spare watch glasses, pipe dope, pipe wrenches, a crecent wrench, valve seats, a quart of good cylinder oil and a big sign that says "No this boat is not on fire".:D
QC
I have found a few stranded boats without a line large or long enough to be towed with . . . I have a few extra lines, so not a problem, but if the rescuer and the rescuee, both are unprepared to tow or be towed, then what?
External Combustion
I like to tow in tandem as it gives me greater control. Even a couple of quarter inch handling lines will get a tow home with both vessels tied securely in tandem. My smallest handling line is 3/8 as it feels better in the hand even for a small boat.
Which leads to another item forgotten on the list....a couple of fenders!
QC
I see this ^^^^^^^ often in and around the marina, but I am not sure about rough water? Thank god you called it a F-E-N-D-E-R . . . pet peeve . . .
jay_merrill
Great post! Here's a few of my tips ...
First Aid Kits
Make your own because most of the ones that can be purchased in a store are "band aid and disinfectant kits." Make up a kit with a large selection of potentially needed items. For specifics on what to include (the list can be long), just "google" the search string "first aid kit contents." You will find lots of advice. A few of my personal recommendations are sanitary napkins (good for controlling heavy bleeding), toothpain ointments for use as a rudimentary topical anesthetic, and a three day supply of any prescription meds that frequent users of the boat must take. Pack all of the items in ziplock type plastic bags and then put all of it in a waterproof container.
Signaling Devices
In addition to other items, I keep several blank CDs in the boat for use as sun reflectors. They do reflect sunlight well and the hole in the middle can be used for aiming towards another boat or aircraft.
Olin Flare Guns (Now Orion Products)
The Olin guns were prone to a hinge failure that prevented the gun from being opened to insert a flare. Orion bought Olin and has been really great about replacing the old guns. If you have one of the older Olins, contact Orion and they will replace it free of charge.
Food & Water
Aside from any food that I might bring for the outing, I carry "civilian MREs" and water bottless on the boat at all times. The MRE's can be purchased online and seem to be made by the same folks who make them for the military.
Fire extinguishers
Not all recreational boats are required to have them. Do so anyway and have more than one, each placed away from the others so that no matter where the fire, you can get to one of them. If you use/store your boat in an areas with insects such as mud dauber wasps, check the nozzles of the extinguishers periodically for mud. I have seen extinguishers that were completely packed from this.
Chemical Light Sticks
Keep a few on the boat - they are great for lots of things. Among other uses, I keep a red, green and yellow stick on the boat as backup nav lights. They can be easily tied and/or taped to the boat in the bow and the stern light pole, and work quite well for this emergency purpose.
PFDs
WEAR THEM! Point blank - while they can't and don't prevent all drownings, they are extremely effective in saving lives. Add to that fact that people who do SAR operations will tell you that the survival rates for those who don't, even if they are strong swimmers, is very low. If you are going to purchase inflatable PFDs, buy the self inflating type and inspect them frequently. That said, inflatables have been known to fail, so I still prefer the standard type. Other than the extra, orange type that fit over the head, which I keep on the boat as spares, I buy PFDs with pockets in them for placing signaling devices. I keep a whistle, a signalling mirror and a small strobe in mine. I will also be adding dye packs soon.
Towing
I made up a towing harness with ball floats on it to keep the line out of my prop. It is not very long, which aids in storage, but it is easy enough to bend another line to it for proper towing. Mine is in a Y configuration so that I can spread the towing stress between both of my stern "eyes." Remember, also, that boats are supposed to have an anchor and line of at least 100' on board. If other lines are not available for towing, the anchor line can be used.
INJUN
A battery powered radio. If you tune to an unused AM channel and hear crackling sounds, it usually means lighining is not far away.
Flash light.
Spare propeller.
Whisle.
Girlfriend:).
External Combustion
CRS is really creeping up on me, so please bear with me. One item that is often overlooked is a pocket knife. Preferably one with a lanyard loop. Everyone on board should have one. You never know when you may have to cut loose a tow, get out of a ski line, get out of an overturned boat or other emergency. You might not have time for someone else to come to your rescue.
Keep it sharp. One with a serrated blade will help on cutting lines, but is almost useless for getting fishhooks out.
QC
My favorite tool on board is the mini Swiss Army Knives. The little key chain ones. Very sharp, scissors work amazingly well, the tweezers are also functional and I am addicted to toothpicks. Would take a little time to cut through a ski or tow line with any pocket knife, but I could get it done with the mini too.
I used to keep one in my pocket at all times, but the scumbags who caused all the changes at airports f'ed that up for me :mad:
Fu-Inator
I'm new around here and to boating but I would recommend having spare fuses.
arks
I'm surprised nobody's mentioned spare motor oil. I've volunteered a spare quart TWICE to assist stranded boaters.
How 'bout jumper cables or a jump box? I've used them quite a few times.
Also, if you're out for more than a few hours, leaving a proper float plan with someone onshore is the prudent thing to do. here's a PDF from the USCG:
http://sioscuba.ucsd.edu/docs/USCGFloatPlan-3.pdf
bhammer
Ensign
Ah, they are great suggestions, some that I have never heard and some that I wish I had the list before my first outings. I just have to say though that you need to take the essentials and weigh risk versus reward. You can come darn near to sinking my 19' runabout if I were to take all these items listed. :D
I have created "go kits" that contain different stuff and are used on various trips. For example, I have a major tool bag that I could change crank bearings (well almost) and one that has a couple screwdrivers, adjustable wrench. In some lakes (3500 acre), I don't need the huge tool bag as it is unneeded weight. Already have to deal with a heavy 19' 8.5" beam boat.
External Combustion
As far as sinking a 19 footer, don't worry about the McGuyver video. The tape along with the player, the TV and the generator to provide the juice is a bit heavy. Watch the series and remember the pertinent facts just before you boat.:D
jay_merrill
bhammer, I agree with you completely - it makes sense to evealuate risk v. need. I carry a number of items that I wouldn't if I operated in relatively small lakes. The food, water & meds are probably items that I would leave behind. On the other hand, since I am often in places that are many miles from civilization, it is prudent for me to be able to survive for a few days if I had to.
For other folks, the decision on what to take and what not to, is going to be somewhere between very little and quite a bit. At a minimum, however, I would want to be able to communicate quickly and render significant first aid immediately.
flashback
I always love these "what to take threads".. I always see something that sticks in my mind that I can stow with my extra water separator, fuel pump, drive belt, etc etc etc... :)
bhammer
Ensign
I agree and add to this. It is the ole adage that when camping or lost, collect the wood for a fire and then when you think you have enough, make it 4 times bigger and that may get you through the night.
I have hit some remote places and I tend to take everything and the kitchen sink. :D My buddy thought it was funny that I took along MREs, even though we packed enough food / water for a 5 day trip that was to last 3. I knew I wouldn't be hungry. :D
I always boat with a very large, very stocked first aid kit. You never know when it may come in handy even if it is a 5 minute ride to the marina. The kit is right in line of importance with a fire Ex. You never want to have to use it, but if you do, your glad it's there.
NW Redneck
Spare drive belt for I/O's is a must! Some spare hose clamps, a couple of lengths of water hose of whatever size is on your engine, and a couple of pipe nipples that will fit the ID of the hoses. Both of those have saved me in the past. :D
ilmostro99
A lot of great advice here, but I tend to agree that if I were to take it all, I would sink. I do a bit of backpacking and when every ounce counts, you tend to only take things that you can use for a variety of problems, and this carries over to boating (and travel, motorcycling, etc.). I never take extra water, I have a water filter (obviously will only work when boating in fresh water). My tool kit is very small. I have what I need to make any repair that I am capable of, but none that would be redundant, i.e., I don't have a hammer, if I need one, I can use my crescent wrench. It may not be the right tool for the job, but if I am on the water, I figure it is going to be an emergency repair that just has to get me back to the dock. I'm not going to be rebuilding an engine out there, and I'd rather save space/weight, than have every "convenience". Once you really start looking, you can find dozens of dual-duty items and save a hell-of-a-lot of weight and space. Use your imagination and get creative. It can even be rather fun.
