Re: 88 merc 80hp
The oil warning system on your engine is for oil level only, I would start by disconnecting the blue wires that go into the bottom of the oil tank. If that does not stop the problem then the oil module is bad and needs replacing. If it does stop it, either the sender that goes into the tank must be replaced of the magnet in the tank is loose and the tank will have to be replaced.
