Magic Joey
Thread starter- Joined
- Jun 2, 2008
- 3
Hi folks. First post here - so hope you guys can help.
I've aquired a Mercury 402 40HP motor. It's pretty old looking but I have no idea what year it is. It has orange coloured coils...if that gives you a clue to the year!!
So it on't start... surprise surprise. I have a spark on both plugs and I have compression. Battery is fine and fuel is getting to the carb. It turns over but won't start at all. I have had the carb off and cleaned it thoroughly too.
Tried with choke open and closed.
When I pump fuel through it's getting to the carb (I know because it's pouring out of the air intake when I keep pumping). It's also coming out of a small hole in the carb just below and to the side of the fuel inlet.
So my first question is.... Is that a drain hole - should it be plugged?
Secondly - with the amount of fuel I pumped through (enough to flood it) I would have expected to see some traces of fuel on the plugs when I removed them again to check - but they were totally dry. It looks like fuel is getting into the carb but not managing to get into the cylinder????
Any help would be much appreciated - thanks.
Joe.
Joe.
