Alpinegold
Thread starter- Joined
- Mar 8, 2007
- 99
I have a Motorguide 550 Brute 41 # thrust that came with a 1979 Ranger V178. I feel like there is integrety in the wiring panel at the front of the boat. It has 4 wires coming from the back of the boat. The plug that goes to the trolling motor is 3 prong. My question is how do I wire the batteries in the back. I am wanting 12 / 24 v system. Have cranking battery and two batteries for the trolling motor. The front panel has 12 / 24 charging switch. The on / off comes from a foot switch. It appears to be just a loop of negative, The system never had a battery switch so I would like to avoid that. On the head of the trolling motor, it has a 24/12 / off switch.
I have wired a stardard 12/24 3 wire hook up using a cross pole.
Here is my problem: When I run the motor with a load at the highest setting in 24 v mode, I blow the 30 amp circuit breaker within 30 secounds. 0
I'm thinking I need to increase the size of wire from the back of the boat to the circuit breakers in the front of the boat. However this is the orginal wiring and orginal trolling motor. Since the orginal configureation was a 4 wire set up going into a circuit breaker and to a charge run switch and then to the plug would there have been less heat disapated in the 4 wire set up than the 3 wire set up that I am currently using.
Also if I increase the size of wire coming from the battery could that mess up the trolling motor?
