Re: Black Max 175 info
Thank you Jason, didn't know it was 1.87:1 I know seloc was wrong when I went to change my jets out. BTW what do you have your 150 on and whats up with it?
And thanks again John. I remembering you helping me out a fuel related problem awhile back. Also have you pulled out the boat yet?
Also is the 87 Mercury 175 Black max non XR have any interchangeable parts with my 89 150 XR4?
Probably a lot of them. There are a lot of variations. The peripheral stuff, fuel pump, starter, flywheels, etc all interchange. Reeds probably interchange, carbs also with adjustments.
The XR4 is pretty snappy right out of the box. You can shave the heads and run 92 octane in it and get another 10 0r so out of it, which puts it near 175 at the prop. After that, yer better off selling it and buying a bigger motor.
If you wanna go nuts with the die grinder and money is of no consequence, I've heard of some pretty scary running engines built up on that block.
The big difference in the XR4 is the smaller, higher geared LU. It was marketed as a hot 150 horse bass bote motor.
By bote's in sorry shape. Motor's on a stand, cables and electrics scattered all over. Transom is cut out. Looking for some time to cut out the floor and deal with the wet stringers. Then I can glue in a fresh transom and put it back together.
Hope to get it back together by the end of the month.
hope it helps
John
