Evinrude 2
Sardar
Hi all,
My Name is Sardar and reside in Toronto.
I will appreciate if someone can help me in recognizing an Evinrude Engine lying with me. I can read the following on it.
Serial # 7056505
Model #2902A
I don't know any more about it.
Thanks
Vic.S
Re: Evinrude 2
2902 = 1979 2hp run on 50:1 mix
Water cooled so dont run it dry or you'll damage the pump impeller (a new impeller anyway would be wise if you are going to use it )
Coil and points ignition
Carb has separate slow and fast mixture adjust screws. The top one is the slow adjust
