where to buy new Skeg?
22Chet
After last season my skeg is pretty torn up on my boat. I was wondering where i could get a replacement to have welded on ?
BAYLINER185
Re: where to buy new Skeg?
If you have a skeg wich Im sure you do just using the wrong terminology...
DEPENDING on how tore up your skeg is a shop can possibly re weld your skeg and build up the damaged areas then bring it back to spec.
OR any marine dealer can order a new skeg and re weld an entirely new skeg on!
Vic
gcboat
If you have an inboard engine there is simply a strut that the prop shaft rides through via a cutlass bearing. Behind that will be your rudder. So is the bottom of your prop strut messed up? :confused:
