Evinrude shaft just a little short
milenine2
I am purchasing 20in transom boat in the next day or so. I have an older evinrude engine which measures 17.5 inches to the bottom of the cavitation plate. I know that this would probably technically be considered a 15in... but I think maybe it is old enough that they were not very uniform on the 15 or 20 standard yet. If my measure tape is accurate it looks like 95% of the prop is going to be below the bottom of the transom and the caviation plate is going to be an inch or two higher than the bottom of the transom. I am not needing performance out of this, it is just something to get by with until I get a long shaft later this year. I am not worried about planing or going fast, especially since this motor is way under powered for the size of boat (5hp on a 16' flat bottom). I will likely be doing trolling speeds 1-4 MPH while fishing. The motor really seems to be inbetween a short and a long by todays standards. I have heard that older motors were often a couple inches off like this. Can anyone give me some expert opinions on this? What should I be watching for when I try it, keeping in mind that I am going to be going slow. Thanks.
Vic.S
Re: Evinrude shaft just a little short
I think that is a 15" shaft model.
The important thing to look at is the water pump. Provided that is immersed you'll be Ok but if it is not then you wont be able to use it. I doubt if will be.
the reason they were longer were the water pumps, had to be submerged.
watch for it running hot.
F_R
Older motors were originally designed to run with the plate a couple of inches below the boat bottom. That's when the 15" transom spec was born. Remember, most boats were made of wood. It is only with improved boats and gearcase designs that we are now able to jack them up without excessive cavitation/ventilation.
Your motor probably will troll OK. It also will probably suck air if you try to go much faster than that.
milenine2
How do I identify "the water pump"? Do I just need to make sure the little intake holes are submerged?
Thanks
F_R
There is the flat anti-cavitation plate. Then, there is a bulge above that plate. The pump is in that bulge.
