timing a 70 hp force?
shrimpman123
how do i bypass the saftey switch to time my engine,at wot with out the sparkplugs installed,.while cranking over the engine? where do i bypass the In gear saftey switch??and how do i bypass it? thanks guys you all are great!
maxum247
Re: timing a 70 hp force?
It is advisible to (remove your propeller) before cranking the engine in gear!
Put a jumper wire from one side of the neutral interlock switch to the other side of the switch and you can crank the engine in gear.
baxtr
You can also use a tie wire/twist tie to keep the neutral switch depressed. Please remember to ground all your plug wires to the engine block, you can destroy your packs if you don't.
