I have a 35hp Mercury outboard and it will not run wide open.
The carb has been rebuilt and it starts and runs fine. When you open the trottle wide open the speed and sound of the motor remains the same. I noticed that when the motor is running the bulb on the gas line gets soft. Maybe not getting the proper amount of fuel?
runs good until put into gear and then it seems to not throttle up the as fast. it also seems to squirt more water out of the pee hole when not in gear.
