Dirttracker
Thread starter- Joined
- Jun 7, 2008
- 14
I can get it running by taking the fast idle timing advance cable loose and working it and working the throttle plate on the advance to open the carb butterflies. I am under the impression that it should idle without opening the butterflies. It also require a lot of timing 20 to 24 deg. to stay running. I try doing the sync procedure but things don't seem to working out. The compression is good top dead center (TDC) is correct, the distr. timing I have move a single tooth each way but can't get just right. The serial # is 4283897 with the thunderbolt ign. I just rebuilt the carbs and have the mixture screw out 1 turn. oh by the way it was running good until it backfired, then it would start back but you couldn't put it in gear and accelarate
