My father just installed a new head gasket on his 1996 v6 4.3 mercruiser. He didn't do the rocker arm adjustment, he just torqued them all down. He tried to start it and it wouldn't run (suprise) I adjusted the rocker arms 1 turn past zero lash following the seloc manual procedure. Ran fine for about 2 mins, developed a bad ticking noise in the valve cover. Pulled the cover and the rocker arm nut is loose again. I'm thinking that when he tried to start it with the valves tightened down it bent a valve? Any other ideas?
