Re: Hardi Board for a floor
Use pressure treated plywood instead.
...., resin soaked on all sides and ends and covered with, at least a layer of 10 oz cloth. (IMHO)
Interesting to reflect, after my resto project, the original plywood flooring was covered with a layer of cloth (weight unknown) then covered with a very uneven application of resin (I assume polyester) So on one hand you coud see the loose fibers of the cloth and on the other you could see where it appeared that the resin had been applied with a squeegee or trowel.
When I did my 'deck', I rolled the epoxy on with a roller, layed down the 10 oz cloth then rolled it again with the same roller. It looked evenly filled and very smooth with just a hint of the underlying cloth.
Weight aside, I agree, the Hardi ??? would be more brittle (less flexible) and not have the span strenght of plywood. Additionally, I wonder how resin and glass would adhere to it.
