reverse only
MSboats
I have a boat with two 200hp outboard motors. on one the warning siren stays on and one side of the motor gets hot while the other stays cool (i did not run it very long). I think that it might be the thermostat.
on the other (starboard side) from reverse to forward or vise versa the gears seem to grind and now wont go foreward. Do I replace the lower unit or pay someone to work on it? I am assuming that the gears are stripped out.
rodbolt
Re: reverse only
post the complete model number of both engines
Capt Ken
Re: reverse only
Just guessing here but I figure the engines are early 90's. One has a stuck open thermostat robbing water from the head that is hot. The other has a rusted shift shaft that has twisted and won't shift into forward.
Lets see how close I was?
MSboats
Re: reverse only
Good guess, both are 1989 model number 200ETXF.
MSboats
Re: reverse only
The shift shaft located on the upper unit? seems to be operating properly
