mercruiser prop shaft question
georay456
i have a 1989 alpha one drive 5.7 it's working fine now but notice that my prop shaft can move in and out maybe as much as a 1/4 inch my question is is that ok ? should i be conserned get it looked at ? or is it going to fly apart next time i use it ?
Muqwump
Re: mercruiser prop shaft question
Is the shaft moving in and out with the prop or is it just the prop? If it is just the prop then i would guess that it is just the rubber bushing inside the prop worn out.
georay456
thank's for the help but it's just the shaft in and out no prop on it
Don S
The shaft does have some movement, but not 1/4". A sixteenth maybe but not 1/4"
Bondo Again
Ayuh,.... Perfectly Normal......
I was going to say 1/8",.... But it might be closer to a 1/ 16"......
Muqwump
Can you a good reading on the shaft movement? Maybe a indicator on the end of the shaft or with a staight edge with a scale?
BAYLINER185
Yea 1/4 inch is a lot. Really maby only a 16th and at most an 1/8th!
