How to start 76 Evinrude 25hp?
wolfman13
I think I just got a great deal on a boat, if I can keep it running. I bought it without having it run. It is a pull start (my shoulders are fried) and I do not have a manual yet. I thought what was the primer button was a kill buttton, so half the day I wasn't using it. What is the proper protocal for how many pumps is normal, etc. Also where should the red arrow be when starting? I thought I had it on start but it was on shift (the words are faded). When I put it down to fast it started. Also where is a good initial setting for the lean/rich dial? The problem I'm having is it runs for a few seconds and dies. The fuel tank bulb is always soft when I check it. I pump it up,it's firm, it starts for a little bit and dies. So it's not getting fuel, correct? I know i need to spray the carbs clean and Maybe rebuild when I get a manual. So is it just the carbs? Do these use fuel pumps, can I check mine and where is it? Thanks
F_R
Re: How to start 76 Evinrude 25hp?
Your carburetor is probably gummed up. Anyhow, connect the fuel hose, squeeze bulb till it gets firm, put motor in neutral, advance throttle (twist grip) as far as it will go in neutral, pull out choke, pull rope till it fires, usually about 3 pulls, when it fires push choke back in and restart if it has quit. Slow the rps down to idle and snap it into whichever gear you desire. Never "ease" it into gear.
wolfman13
How do I know what rebuild kit to get? I did a quick search and actually 2 came up for for my year and model, one for $12, the other for $14. How many times should I be presssing the priming bulb, along with the fuel tank bulb, and with the choke out? And also, where is the best place to get a rebuild kit? And a service/owners manual?
wolfman13
These came up for a Johnson 28HP, both the carb kit and the manual. I have a 76 Evinrude 25 hp, Model#25602E. Where can I find carb kit and manuals? On ebay, I've seen parts catalog, owners manual and service manual. Will one be better than the other?
