enginesilo
- Joined
- Jun 9, 2008
- 355
I am shopping for a bow rider and found a boat with a year 2000 Johnson 115HP Outboard.
What are some things to check when shopping for an Outboard?
1.) Compression - What is ideal compression in this engine?
2.) Charging System - I recall holding a meter on the battery terminals at idle and then while revving in the past to see if the number climbs as the engine is revved. Is this a sufficient test?
3.) Check for corrosion and leaks
4.) Make sure the engine is pissing water out and cooling
Anything else to check?? Tips appreciated.
