Johnson j90plss fuel bulb
garblnk
Fuel bulb will not stay hard. I have to keep pumping to prevent the the engine from cutting off. After awhile it will run fine even at WOT. I replaced fuel bulb still same problem. Boat ran fine after launching first time this season. Put in fresh fuel and problem started soon after? Johnson j90plss
Joe Reeves
Re: Johnson j90plss fuel bulb
In pumping the fuel primer bulb, you are acting as a manual fuel pump. If there are no air/fuel leaks anywhere in the fuel system (lines, connectors, etc), rebuild or replace the fuel pump.
