capnrobalo
- Joined
- May 15, 2005
- 22
Hi,
I have a problem with my motor getting fuel under the following conditions:
1) when the fuel level is low (after a day of offshore fishing)
2) when the seas are rough
Basically, what it boils down to is that on my way back in from offshore, sometimes when the boat pounds the water after going over a big wave, the motor rpms suddenly drop without me touching the throttle. Usually, the motor continues to run but at low rpms. Sometimes but not usually the motor cuts out entirely. When either of these symptoms occurs, I have noticed that there is air in the priming bulb. And if someone constantly pumps the bulb, I can keep the motor running just fine at 4000-5000 rpms. Of course this is quite annoying and scary and I would like to get it resolved before going offshore again.
My mechanic has attempted to fix this problem in 3 or 4 different places but without success. Now I am now trying to take care of it myself. I believe the problem is a poor design on the fuel tank/withdrawal system but I'm not a boat builder and don't have much experience with marine fuel systems.
The fuel tank is a 99 gallon aluminum below deck tank. I don't have access to remove the tank, but today managed to remove the pickup tube. Attached are a couple of pictures of it. To me, the pickup tube looks suspect. It seems to be bent upwards near the end of it which seems to me like a problem when fuel is sloshing around in the tank. I suppose that this is something that occurred over time and was not part of the original design. Also, why is there a plastic fitting on the end? It looks like it possibly connected to another tube or filter or something. Also, does it seem kind of long for a pickup tube or is this normal? I am under the impression that a pickup tube normally sticks straight down and off the bottom of the tank a quarter inch or so.
Anyway, can someone offer some hints or suggestions as to how I can resolve this issue? It is frustrating always having to limp back in from a day of fishing. And if any more information is needed to help diagnose the problem let me know. Thanks for any help!
Jason
1996 Robalo 2120
Jason
1996 Robalo 2120
