Cover boat when towing?
I soon have a 300 mile one way boat trip planned. I was wondering is its safe/ok to cover the boat and tow it? I have been told a couple a different things. My main idea is to not create so much drag and also if it rains to protect the boat. I have a blue shrink wrap that i re-use as a cover would that be a good idea if i secure it on there good?
Expidia
Re: Cover boat when towing?
I doubt that will work. Trailerable covers are fit tight to the boat. Trying to trailer with a loose fitting tarp, it will be torn by the wind very quickly where ever the material is flapping at highway speeds.
Unless you are using the boat to store stuff while traveling I would not bother trying to cover it for just one trip! Many people moor their boats uncovered.
What you can do is when you stop like at a motel cover it then with the tarp and some bungie cords to keep it on.
Oops, sorry. I thought you said you were going to use a tarp.
jtexas
Get yourself a cover made for the purpose. Use straps running under the boat (vs just securing the edges to the trailer). add at least three straps that run over the top of the boat (to keep the wind from getting up under there).
If the edges are secured all the way round, you won't have any problems.
kenmyfam
I tow with my tonneau cover on if I am going a good distance as I usually have all kinds of stuff stored in there if going away for a trip of a few days or more. It is very close fitting and does not flap around at all. No issues so far. If I am going locally then it's cover off.
SpinnerBait_Nut
Mine stays covered all the time when not in use.
Going and coming it's covered with the Gambler cover.
arks
Back when I trailered a 23 footer I had snap-down cockpit and windshield covers made by a local shop. No hull straps were used. I had the windshield cover made because of a prior bad experience. They both worked OK but I discovered they would un-snap along the top of the windshield if wet and travelling over 60MPH. The easiest solution was to slow down a little when it was raining (DUH). We regularly trailered over 250 miles and never had any other problem with the cover.
A VERY good reason to cover your boat when trailering is because some ignorant person could flick a cigarette into the boat. I know someone who lost his boat due to this. Fortunately the gas in his tank didn't ignite, but it completely ruined his interior. Insurance got him a new one but it was not a pleasant situation.
the cover has to fit perfectly, or it will beat the boat finish to death. i prefer to tow uncovered.
topdawg1817
I agree with some of the others. You need to have a tight fitting cover that goes on otherwise you will end up beating your boat up really badly. I have noticed with my cover a few spots were it has rubbed some spots off of my registration numbers.
jaxnjil
i would cover it. i see boats all the time on I 80 that are shrink wraped. the only thing with yours is whether reusing the wrap will retain enough integrety to stay on at hiway speeds.
we had a cockpit mooring cover made for our boat just to use when we are trailering. we got caught in a thunder storm last year in utah and had 4" of water in the bilge, every thing got wet, and it took 2 days dry every thing. that pluse the fact you dont have to worry about stuff blowing out and your property is out of sight when you stop makes me feel a lot better.
Thunder_SS
....plus the fact you dont have to worry about stuff blowing out.....
This has been my worry all the time. I have the bow cushions that are just laying on the fiberglass, and then I have the back cushions on each side of the engine that are velcro'd down, but would you really trust that velcro when you pass a semi truck at 65 mph?
Plus, how bout you inflatables that you haul to the lake, life jackets, fishing poles....etc. etc. The list could go on.
I think its a pain to put the cover on when you get out of the lake, but I have always thought that is part of boating. I immediately take the cover off before I back it in the garage!! Of course, to let stuff dry out.
jtexas
I used to inflate inflatables at a gas station compressor or whatever and strap 'em down.
One day it occurred to me to try our camping air mattress inflator, which I got a wallymarts who knows how many years ago. Plugs into a cigarette lighter.
Fills up even the big towables real quick, and ya don't even have to do it before you get to your playground.
kenmyfam
That's what we use. Great !!!! fill the inflatables before we go out....or when we are out and had enough tubing we deflate using the same pump in the power outlet I fitted and go ski-ing. Always carry the 12 volt power pack though and use that so as to make sure the boat battery is charged and as a back up in case I need a boost !!!!!
642mx
I have a cover from Westland thats a trailerable cover. I hardly ever tow it covered, unless the weather is bad.
Jack Daniels
I always tow with a cover, in fact, my boat stays covered at all times unless on the water or in the garage. I know its probably over kill, but i dont want to take any chances.
12vMan
I always tow with a custom cover I had made.
It's paid for itself I'm sure, because I've never lost a cushion or item I've had in the boat yet.
I recomend having a cover made and using it.
Irv964
Mine is covered always when travelling, I use the eyelets to secure to the trailer and then use adjustable bungie straps for the top side. One on the bow, one just behind the windshield and another at the back, these keep it from billowing and scuffing your paint. I have done it this way for 10yrs with out an issue........Irv
I have two covers which I have made for my boat. the full cover which goes over the sides is when it is parked and I have a snap on cover that I use for towing. Both are made from Sunbrella. When I made my towing cover, I put the snaps extra close together at the base of the windshield to prevent them from ever coming loose.
I designed my storage cover to be towed with as well using many tie down points.
kenmyfam
Looks really good Bruce. I hava a very similar one to your snap on one for towing. The snaps are very close together where it needs to be.
franco802
Very nice boat!
While the cover does protect the contents and the many reasons for a good fitting cover have been indicated, the best reason for using a cover is to get better fuel economy. A covered boat creates far less drag and results in significant fuel savings.
