I have a virus! Any help appreciated.
WizeOne
Re: I have a virus! Any help appreciated.
Ok pop's a little "fore" warning stay away from questionalbe site's...:p
I persoanlly dont know if your mechanically inclined....:D but if you have two comp's you can alway's take the drive off the infected comp install it as a secondary on the working comp. Then do a virus scan on the second drive Ummm first update you virus ware..Are you using ariva that prog will get the bug ...Geesh some people's grandads's.......;)
http://majorgeeks.com/AntiVir_Personal_Edition_8_d955.html
Not a bad suggestion from a snot nosed kid. :p
I just may give that a try. I just identified a possible executable on a google search, pasted it into 'search' and the dang thing shut the computer down withing seconds of starting a search for that file.
The_Kid
This site uses an online scanner instead of having to install a program. http://www.eset.eu/online-scanner
It may not remove everything but it will usually get enough to where the other scanners will start working. I maintain about 150 PC's and it's been a life saver a couple of times.
[Edit] I didn't see your other post where you got rid of the virus until after I posted this. Glad you got everything runing OK again.
WizeOne
Yeah, everthing is still working swell.;) Thanks for the link anyway. I will tuck it away for further use.
EDIT: I dunno Kid, I just went to try it out and after hitting 'start' it came up with "Click here to install the following ActiveX control:~~~~" A request to download this was what gave me the infection. It has the exact same Security shield that the spyware that I had.
I don't think I'm gonna touch it.
Tail_Gunner
02
Mod Alert Mod alert...i was just called a snot nosed kid by a :eek: Wize one....ban him......:mad:
By the way that will work pop's
