Shadetreeboatmechanic
Thread starter- Joined
- Jun 15, 2008
- 11
Hi, I too am new to posting on this forum, but I have been a reader for sometime now. I have learned so much and found so many answers just by searching the old posts. Thank you to all who post on this board.
Now for my problem. First of all my husband & I are shadetree mechanics. He has a very general knowledge of mechanics as he worked as an auto mechanic for a few years. I do all the reseach and reading to give him the directions. We have a '86 140 Mercruiser with Alpha I outdrive. Standard cooling system. I do have an orginal shop manual I think I almost have memorized. We have an overheating problem and an idle problem. Here's what we have done and what the boat is doing.
We took it out a couple weekends ago (1st time this year). Ran it for quiet some time at around 3000 RPMs just cruising. No problems except for a miss going from idle to accelerating.
We took it out a few days ago, Still had slight miss but if you feather the shifter through that point it runs great. We ran it for about 10 minutes at Full throttle. It overheated BIG TIME. We sat let it cool off then slowly cruised back to dock. It did not overheat at low speed but still had the miss.
We brought it home took entire upper cooling system apart. We found the thermostat was broke, the exhaust manifold and riser were clogged. We cleaned them both throughly replaced all gaskets & thermostat. Changed Oil and filter. Checked the water lines going through the transome. All clear. Lower Unit impeller was changed last season) Started it in the drive with muffs. No overheating at all and she was throwing more water than ever.
Took the boat out yesterday morning. Other than the miss going from idle to to accelerating it ran great, no overheating problems at all. We ran it for 30-40 minutes at Full throttle and it never got above 160.
So when we got it home we decided to tackle the idle problem. We removed the carborator cleaned it throughly. Cleaned all the fuel lines. Checked all the plugs and wires, both still look brand new (replaced last season) Checked all the wires for corrosion. Hubby lightly sanded the points. Did NOT adjust timing. Started it in the drive with muffs. Great water output. Ran great no miss. Soooo we decided to go for another test run.
Put the boat back in the water. Started great. Ran Great after hubby adjusted the idle a little. Idled out of the no wake zone hit the throttle she took off and ran beautiful Until it OVERHEATED again!! We let it cool while watching the storm clouds roll in. We idled back into the dock still overheating but it was a nasty storm coming and we had to get off the water. Loaded it up, came home, parked it in the garage and came in the house. We are stumped!!
We don't have a clue why. Can someone please help us figure this out. We have talked to a couple real mechanics and they don't have a clue either. Said possibly the timing but if that was the case why did it not over heat on our first run out yesterday?
All help is greatly appreciated. This is driving us nuts!!
