Engine Compartment To Hot?
Dshow
Hi all,
I have a 2001 5.7L Mercruiser (sn 0M080869) with throttle body injection. Yesterday, we had a boat full (4 adults & 4 teens) to go tubing. Ran great for about 45 min. We stopped to exchange tubers and would not run again. Initially it would crank and fire, but when I tried to give it gas, it would die. Then, after a couple attempts, it wouldn't fire at all. It seemed like it was starved for fuel... I kept an eye on the temp guage and didn't see any overtemp but it was hot in the engine compartment... (I was prop'd very low, when pulling, RPM was ~3500 but speed was only 15-20 MPH.) I let it sit for for a few minutes (not very long, 8 on the boat...) and still would not start, so we go a tow to the ramp. When I got home an hour later, it started right up... I looked at the contents of the fuel/water seperator and it looked like all fuel. Today, it started right up again. I let it idle for a 5 min or so, and ran fine. I have a scan tool (didn't have it on the boat...) and there we no codes. I originally thought it was my fuel pump because it has sounded like crap on prior starts, but I can still hear the pump and it ran today...
Any ideas on what could have caused this or what I should look at when this happens again?
Thanks
Dshow
Re: Engine Compartment To Hot?
Thanks for the replies! I did a little more investigation using the Merc manual and I have a fuel pressure sensor on the throttle body, here's a pic looking down from the top. So I guess I will start with that reading if it acts up again...
Coors
Like it wasn't getting fuel?
Dshow
A car fuel pump has a nice hum to it. This pump sounds like a bearing is going out, but it's been that way for the last year or so. Are they supposed to sound that? Won't reading the fuel pressure tell me it it's going out?
Thanks.
Coors
Old, pre-fuel injector, here.
Bad bearings noise un-familiar. Pumps make noise when not getting fuel.
Have you checked that it is getting fuel?
BoatingCop
I had the same problem with my 4.3 carb. It seems if when it started acting up if I opened the engine hatch and let some of the hot air out, it would be fine. When it does happen, I just leave the blower on. It rarely acts up though.
