Hey folks
90 hp 1998
Long story short ( did not real all directions just some) took LU off to change impeller, was in F when I took it off and put in back on in Neutral. Dropped the boat in the water today and only had F no matter what gear I was in. Even Neutral had a small push to the boat.
Took the boat out of the water and there at the ramp I dropped the LU off again. Not being a mechanic I was totally guessing at what I was doing. Using pliers I shifted the LU into N (no I did not damage the shaft or cut gears in it). I checked that it was N because I could spin the prop both directions. I then set the shifter on the helm to N and the bolted the LU back on.
Put boat in water again and tried it out and found I had nothing but N.
What am I doing wrong? How should I properly realign the linkage so that when I put it in F it moves foward and when I put it in R it is in reverse?
Thanks for help. what makes me mad was that this was a result of trying to do preventative maintenance.
90 hp 1998
