Flywheel thread
MillBubb
1968 Evinrude 65 horse Sportfour
The threads on my flywheel are indistiguishable. Anyone know what they are?(a HeliCoil will suffice right?)
Thanks!
F_R
Re: Flywheel thread
5/16-18 if I am not mistaken.
MillBubb
Re: Flywheel thread
All agree? I want to be exact since I'm correcting them.
Thanks
Re: Flywheel thread
don't really understand the question. if you are talking about the holes for the puller, they very well may be full of threads, from a soft bolt someone tried to pull flywheel.
MillBubb
Re: Flywheel thread
Yes that is what happened, the threads have been stripped out. I can't tell what size they were. I've been lucky getting the flywheel off.
Re: Flywheel thread
i believe F_R is correct. what happens when using a soft bolt, is the threads are left in the flywheel from the bolt. try taking a tap and work them out.
ezeke
Re: Flywheel thread
Tap up to the next size bolt instead of the helicoil, even if you go to metric. I don't think the helicoil repair is strong enough.
samo_ott
Re: Flywheel thread
I agree. The helicoil will rip right out. Go one size bigger and re tap into fresh metal.
