How do I perform a Leak-down Test?
JustJason
Re: How do I perform a Leak-down Test?
its easy.... first you buy a big compresser... the bigger the better.... then you buy a leakdown tester..... then you google "leakdown test"
what's your problem?
joseph.signore
I'm getting raw water in all four of my port side cylinders and water in my oil. I have a 1991 5.7 350 magnum Alpha one mercruiser. I changed my risers, exhust manifolds and checked for blockage out to the stern drive and still have the problem. the moter runs fine with no skip however when I shut the motor off the cylinder fill with water again.
JustJason
what brand of risers/manifolds did you buy? where they new or used? did you check the mating surfaces for flatness? did you put the gasket on dry or with some kind of sillycone?
joseph.signore
Mating serface look good no paint... I used all OEM Merc Cruiser parts and gaskets, all brand new. I had this same problem with the old manifolds and risers, after replacing them, nothing changed. I did not use any silicone sealant anywhere, just the merc cruiser factory gasket. The reason I changed the exhaust manifolds and risers was because they were looking old and I thought they may be the problem. Again, changing them has made no difference at all. I am now worried about water doing damage to my engine, I've been constantly changing the milky oil after testing and fogging the engine and cylinders
