alskntwnsfn
Thread starter- Joined
- Jun 17, 2008
- 8
Here's what I know about my boat, which unfortunately isn't much:
1. The outdrive is a OMC, electric shift. The outdrive model number is #981227, 225 HP. The lower unit is probably 2-3 years old, so says the gentlemen I bought if from last summer. Even though the unit is 'newer' I believe it was manufactured back in the late 70's or early 80's and has been rebuilt. The SELOC manual that came with the outdrive covers units from 1964-1986, and the unit pictured on the cover looks exactly like mine.
2. I think my engine is a Chevy 350. My identification says the engine model number 990211A11. It's got about 820 hours on it, and runs well, but has had a number of electrical connector problems.
About my problem:
Took it out the for the first time this year, it shifted into forward easily in the harbor. We trolled out of the harbor and I started pushing up the RPMs. I got to about 2500rpm and it came out gear, going into neutral. No grinding or anything from the outdrive. It just came out of gear, and wouldn't go back in. Again, no grinding or noises, when I flipped the gear switch into forward/reverse, there's just nothing. We let it idle for about 15 minutes while I warmed up the kicker. Then we noticed the engine was overheating.
Now a few days later, we've replaced the starter, because it had a broken bushing. It starts much better, and still idles fine. It didn't have any overheating problems while we let it idle for about 15 minutes in my driveway (while we had the garden hose running water through the outdrive). We check the ohms going into/out-of the outdrive, and they all read a normal 12, depending on whether its in fwd or reverse. Finally, the prop pin is fine. That hasn't been sheared. We've been hesitant to start taking the outdrive apart, as we don't know much about it compared to engine-related matter.
One more thing:
- The outdrive gear that links up with the engine does not spin when we spin the propeller. The prop spins easily, that outdrive gear however can not be turned by hand.
Does anybody have any ideas about what is going on here? Is the problem a bad switch up by my ignition (the only "easy" thing I haven't checked). Is it a problem with the electrical cables, or the magnets, or something else? I guess I'm just looking for some guidance as to what could be the issue with it not shifting into gear.
About my problem:
One more thing:
