How to check for exhaust leak?
sat1962
Does anyone know how i can test for exhaust leak I have a 1988 70 johnson new fuel lines, new powerpack, new fuel tank, new fuel pump, cleaned and rebuilt carbs, new head gasket, new intake gasket....... looking over my shoulder so my wife doesn't see all new parts...... and it still sneezes and runs like an anchor! My kayak runs better!
Any help much appreciated..... looking forward to the day I can come back here and say it runs great. :confused:
CATransplant
Re: How to check for exhaust leak?
If you suspect that an exhaust leak is choking your outboard out with the hood on it, try running it without the cowling. If things improve, then you should suspect the exhaust leak.
I do note, however, that you don't mention a compression test on this engine. Have you done that?
sat1962
it does run with the hood off
i did a cmpression test couple weeks ago but im going to do one again the one i did was #1-120 #2-119#3-120 how do i check exhaust leak
flabum
If it runs good without the hood, then you do have a leak. Two places....
1) The side cover gaskets This should be pretty obvious as there will be a blackened area where the gases are escaping. You can use soapy water to locate the leak with the engine running IN THE WATER. It has to be in the water to create back-pressure.
2) Powerhead base gasket leaking.
sat1962
is there a way to test the powerhead base gasket and how big of job is it to replace it if it is
wilde1j
You're going to have a new motor soon, all done with parts replacement. You need to start troubleshooting in a logical way, rather than jumping all around and putting new parts in.
