1986 searay 140hp I/O
skynyrdcat
New to mercruiser engines...
Are these chevy engines?
Forgot to write down the numbers, but I can get them tomorrow.
It look very similar to a 2.5 chevy motor I rebuilt several yrs ago. If so, are their any different parts between the two (that will not interchange)?
Thanks in advance!
Re: 1986 searay 140hp I/O
Cam, crank, pistons, water pump, oil pump all the same?
Nope,....
The 4 cyl. Marine motors have No automotive cousins....
chiefalen
the 2.5l chevy motor is a 120 hp engine. were used in chevyII cavailers and chevy pickups way back.however the 3.0l 140hp motor was never used in a automobile.no u cant use a automobile fuel pump,alternator,or engine mounted water pump in a marine engine.the water pump in marine engines has brass vanes or are supposed to.the alternator is sealed no sparks,enclosed area fuel vapors don't mix.fuel pump marine engine has a return to the pump from the carb.so fuel doesn't pool in the bilge.marine engines run at a higher rpm for longer periods a auto.engine dropped straight in a boat would not last very long.
skynyrdcat
Makes sense to me!
Thanks for the info guys.
As always, iboats is a great place to find the information I need!
