More HP for your 4.3, 5.0, & 5.7!
Willyclay
Re: More HP for your 4.3, 5.0, & 5.7!
Let us know the results on your truck. Good luck!
fixb52s
Carb spacers have been around for YEARS. My grandfather was making them for old flatheads in the 50s. They do work on some engines, but don't really do much for a stock engine.​
MikDee
Banned
Yes, it's not a new idea, they've been using them for yrs, but they only work on carbed or TBInjection. I'm looking for some extra grunt for my recent 95' V6 S-10 pickup for towing. Low end isn't bad, but it runs out of breath at 40-50mph. They used this principle on the old 63' Dodge ramcharger 426, it had a hot cam, then to recover low end torque they gave it a ram effect long runner intake manifold, but it also helped all through the rpm range. Along with this, there is also a seperate injector spacer to raise the injectors up a bit out of the airstream, that also helps, it's at the lower part of this page:
http://www.ttmotorsportsinc.com/throttlebodyspacer/index.htm
Here's the theory behind it:
http://www.ttmotorsportsinc.com/theory/index.htm
Gary H NC
Don't expect much difference with that type of fuel injection..
All your throttle body does is allow air in...no fuel like the older TBI motors.
It would make a better door stop...:rolleyes:
MikDee
Banned
Gary, My recent 95' S-10 has TBI, it has 2 injectors right on top, it mixes fuel, & air, so it will work, it's not port injected, CFI, nor CSFI.
Gary H NC
Thats right...The change was about 98 or so on the throttle body.
Sorry.Let us know if it helps...:)
thumpar
Wierd, my 94 safari (4.3l) has CFI.
