nautiquetroy
Thread starter- Joined
- May 10, 2008
- 5
I have a 50 hp tohatsu mid 90's and the engine has 120 lbs compression in all 3 cylinders and idles and runs out fine, problem is that at 3/4 throttle the engine runs good for about 5 mins and then drops a cylinder until I back down to 1/4 throttle and then runs fine back at 3/4 throttle for another 4 or 5 minutes with the same result of one cyclinder dropping off. I cleaned the fuel line connection to the engine. I assume this sounds like fuel, haven't checked the fuel pump or screen (if there is one). its running off a portable tank, vent is open, pretty sure theres no water in the tank. Any ideas on problem?
