Hi, I have a 1980 johnson 140hp outboard. It will run idle ok but when in water if I apply throttle to move, the engine will die out. I have noticed from taking out the plugs and checking them against the housing, that one of them is producing no spark. I've ruled out a faulty plug by swapping them around and the fault is still in the same cylinder. Before I start more extensive trouble shooting, is there anything I should be looking out for that may cause this?
I am assuming that the motor dying out is related to the spark problem.
