Transom Plate Removal
Texel Tom
Hi
Have a 1981 Sportcraft with Merc 470. Pulled engine and leg and fixed cam seal water leak etc. Found soft transom so now need to remove transom assemblyand repair.
I have disconnected everything from the inside of the boat, steering, trim/tilt pipes etc but now face with the task of removing the transom plate and gimbal housing.
How is this done? is it just a case of removing the 4 lower nuts and two upper screws and prizing it all off? Or is there other stuff I need to do or remove. I just want it off, repair the transom and re-fit it as easy as possible. The gimbal housing was fully serviced last year with all new bellows etc by the last owner so I don't really need to go there again.
I would very much appreciate any tips and directions.
Thanks Tom.
xltier
Re: Transom Plate Removal
yake off the exhaust pipe and all hose.remove the nuts and bolts u mentioned and remove the transom assembly from the back of the boat.you have the hardest part done already.as far as removal.you will have to undo the power streering to get the inner plate out of the way.
Texel Tom
Thanks, I just needed reassuring. What is connected between the inner plate and the outer gimbal housing - I can see that the shift cable is anythin else?
Also what parts will I need to replace (gaskets etc)?
Tom.
xltier
everything should pull rite out with the transom assembly.at least it did on the one im doing.there is a rubber gasket between the transom plate and the transom.i had one of those that leaked.
