I have a 18'2 " nitro with a 7" setback, 150 xr6 with a 23 tempest. I am running the tempest 23 at 5800-5850 rpms at 58 mph with 2 guys and a tournament load. Mercury calls for Max RPM of 5000-5600 RPM. The motor is running above the pad with the cavitation plate about 2-3" above the surface of the water at WOT. I have had the motor as high as two holes higher on the jack plate but it scared me. The boat ran great (cornering suffered) but the cavitation plate was 5" above the surface at WOT and even with the top three holes epoxied closed I worried about the water pressure even though the gauge seemed fine. Max rpm was the same as it is now 5800-5850. The motor is not moving again (the X factor will not change). I have trim extenders on order due to the negative trim angle built in to the setback. Boat test.com said they ran the boat at 61mph with a 25 Tempest. I am looking for a better prop. Tempest 24-25, Turbo Lightning?
Tempest 23
5800-5850 rpm
58mph(GPS) 2 guys tournament load
Full trim, rooster tail about the hight of the motor hood(no higher) prop shaft level with waters surface.
Tempest 23
5800-5850 rpm
