1984 85 hp slipping out of gear at WOT
timdan94
My 85 hp force seems like it is slipping out of gear at WOT at cruising speed. Does anyone know how to fix this issue?
Thanks
Dan
timdan94
Re: 1984 85 hp slipping out of gear at WOT
I'm new to the site and new to owning a boat. Anyone have any idea about what is wrong?
ck85abc3
Some people do, just give them a little time.
Does it clunk when it is slipping out of gear?
You can also try searching clunk, gear slip, jump gear, etc... Make sure you are searching under the force forum only.
timdan94
yeah it does clunk.. the motor doesn't lose power or anything it just slips out and then right back in.
ck85abc3
Here is a thread I posted about the same problem and same year motor. I'm just running it but keeping my rpms below 5000 and I don't have problems.
http://forums.iboats.com/showthread.php?t=202036
Here are more threads related to the issue.
http://forums.iboats.com/showthread.php?t=151237&highlight=clunk
http://forums.iboats.com/showthread.php?t=148082&highlight=jumping
http://forums.iboats.com/showthread.php?t=178249&highlight=clunk
http://forums.iboats.com/showthread.php?t=154920&highlight=clunk
timdan94
thanks for the info
timdan94
I just had the boat out tonight and it seems like it just might be a linkage adjustment because it slips in and out of reverse at lower rpms... and out of gear at really low rpms and wide open throttle when already up on plane....
airframer
could be a worn out clutch dog. if the adjustment doesn't help, you might have to tear into your lower unit.
