9.9 Johnson Sea Horse
ish
I have a 9.9 Johnson Sea Horse that I don't know the year of. The Model No. is TJ10ELESC. I'm having some problems with it starting when it sits for an hour or more, but when I get it started it really runs fine. Is it fuel line, or carburetor, or? Can anyone help?
HighTrim
Re: 9.9 Johnson Sea Horse
Welcome to iboats.
It is a 1990
What is your starting procedure.
wejsunek
let check a carb valve..may be during this "one hour" a fuel is a little going in to engine.. boat is swinging... fuel is drop by drop flying...
andrew
ps.sorry for my bad English..
ish
High Trim
Thanks for the info.
I usually turn the ignition key while activating the choke with the accelerator extended a little. If I do this within 15 minutes to 30 minutes the motor usually starts right up, but if its a longer period then I have to try and try. Most often when I check the gas line bulb for firmness I squeeze it a couple times to be sure its firm. Sometimes i don't use the choke though and it starts right up.
Vic.S
I understand what you mean, I think.
That could happen if the tank is higher than the engine but not if the tank is lower, unless the vent is being shut and the tank is presurisng in the sun.
wejsunek
generally yes.... I have very similar problem with my 9,9HP Johnson...sometimes it is necessary use choke after 5 minutes .. sometimes not after one hour....so ..I have not any definition this phenomenon
andrew
