Need Help Quick
zach103
how can i remove a screw thats completely stripped.. it was a square bit. now its more like a circle. and its completely in the wood.. i cant pry it out
gstanton
Re: Need Help Quick
Hopefully, you can take a hacksaw blade and cut a notch across it... then use a straight edge screwdriver to unscrew it?
OR get a set of needle nosed vise grips and try to clamp onto it and back it out.
OR...
Next step is to visit Sears or your local hardware store and look for screw extractors. Most of them are something you drill/screw into the head - backwards - and then turn the whole thing back out. Good luck.
zach103
Re: Need Help Quick
Jerico it worked great.. i got mine at home depot from some other brand but same design.. simple and easy to use. wish i knew about that b4 i threw my phone across the yard in annoyance :)
ThumbPkr
Re: Need Help Quick
I think I just saw your phone go by..................Ron G
zach103
Re: Need Help Quick
hahahha wouldnt be surprised. your close enough
Re: Need Help Quick
Could use a dremel with a small cutting wheel to slice a slot in the top so that you can get a screwdriver on it.
