cracked y-pipe vs. thru the hull
Engine is pulled and found a cracked y-pipe. I read many threads about thru the hull exhaust. I'm not concerned about the noise factor, I'll be below the water line and its only a V6.
I have a 1993 4.3L Vortec. I was planning on putting thru the hull because the cost of a new y-pipe (and pipe with water flaps. one is currently stuck in my bellows).
I read a string that said this is very difficult?
Any advice on 3in or 4in?
Where can I find a elbow that will fit with my existing stock parts?
Also I read this can hurt my performance? This does not make any sense to me?
Thanks in advance for your comments and advise!
MikDee
Banned
Re: cracked y-pipe vs. thru the hull
Not really too hard to do, just get some 4" marine exhaust hose, and 4" exhaust elbows (they should be readily available, try E-bay) or try a search, a couple of thru-hull shorty tips, mount the tips where it's clear, and pipe to it, using cut up sections of exhaust hose, with double hose clamps at every joint. I don't think you'll lose performance over a thru-prop exhaust, but if it were a 3.0 4cyl engine, it might be questionable. Just make sure you leave room for your steering shaft movement.
I would stick with a new Y-pipe.
